Problems Starting
Old Dec 1, 2010 | 11:58 PM
bcasey211's Avatar
Default Problems Starting
I have a 99 Trans-Am and have been having issues starting up lately. I can hear the fuel pump starting up when I turn the ignition to acc. But when I go to start up it turns over like it is out of gas. But then on the next try it will start up fine. My neighbor who was having the same issue says its the FPR. Is this right? If so does anyone know the model # for it? Thanks for anyones help.
Old Dec 2, 2010 | 10:45 AM
Nasty N8's Avatar
Could be any number of things you need a pressure gauge to check when it looses pressure. But it sounds like the pump check valve is bad. you could turn the key twice before trying to start and it should fire right up.
Old Dec 2, 2010 | 03:18 PM
bcasey211's Avatar
If it is that. Where is that located?
Old Dec 2, 2010 | 07:49 PM
Jimmy P's Avatar
In the fuel tank.
