Fuel problems...need advice please
Old Feb 5, 2004 | 09:35 PM
Ghost SS's Avatar
Default Fuel problems...need advice please
So I hooked up a fuel pressure gauge on my car today to see what is wrong with it. NA at idle and WOT I get about 60psi of pressure On spray at WOT my fuel pressure bounces between 48-55psi So my first guess is my fuel pump is having some trouble Could this be an injector problem since it is bouncing around so much
What made me check my fuel pressure is when I am spraying my car starts to backfire really really bad.
Any advice would be nice...thanks.
Old Feb 6, 2004 | 01:02 AM
Nasty N8's Avatar
I would rec. at least a pump you are running out of fuel on the spray. What is your setup...what mods and what hp level? Let me know and I can set you up with what you need.
Nate
Old Feb 6, 2004 | 02:19 AM
Ghost SS's Avatar
car is pretty basic....LT headers, true duals, lid, LS1edit tuning...car put down 330rwhp NA.
I spray a 90shot of nitrous, dry kit...car put down 413rwhp on spray. Car has 96k miles on it.
Old Feb 6, 2004 | 02:57 AM
silverTA's Avatar
man u need a bigger intank fuel pump and 30 pound injec if u will be spraying a dry kit.
also u got a 99 and they came with a smal inject 26
Old Feb 6, 2004 | 10:55 AM
Nasty N8's Avatar
Agreed I would replace the pump and step to a bigger injector to be safe.
Nate
