did i fix it
Old Dec 10, 2010 | 07:45 PM
dwnshft82's Avatar
Default did i fix it
i am in the middle of a new build before i started i Had fuel pressure problems the fuel pressure was steady at 58 pounds at idle and lite duty but as soon as i hit the gas it wold drop to 30 to 40 pounds i had a shop install a walbro 255 a while back well i decided to check the install well i was doing my build i found that there was no modification to the bucket so i cut both sides out and the bottom buy the intake hole do you think this will fix my problem or should i dig further for more things that could be wrong
thanks for the advice
