Having a problem starting
Old Dec 15, 2010 | 03:53 PM
revinkevin71's Avatar
Default Having a problem starting
Car usually won't start when I first crank it over. It usually takes anywhere from 2 to 4 cranks before firing. Any ideas?
Old Dec 17, 2010 | 03:01 AM
Bobatsuperior's Avatar
What year is your car? I had the problem with a 98 TA, it turned out too be a leaky injector was killing the fuel pressure in the rail. I took the bolt's out of the rail and seperated the rail and intake turend the key on a few time's and watched each injector, with they key off my #7 was leaking down, replaced the set, started perfect every time after that.
Old Dec 18, 2010 | 02:11 AM
topspeed7's Avatar
could also be a bad fuel pump check valve, its built in the pump so u have to replace the whole assembly, also could be a bad regulator which is also built in the pump assembly.
