600+ whp on E85
Old Dec 23, 2010 | 10:54 PM
Tengis's Avatar
Default 600+ whp on E85
This is not in relation to an Fbody and/or LSx engine but a Wbody (aka Grand Prix) and a big turbo setup on a 3800. I figured someone on this forum might have the answer to this question.
Im trying to figure out what my best route of having enough injector would be. I have the capability of running dual injectors pretty easily - I wouldnt have a problem running say two sets of 80# high impedance injectors. The cost of running low impedance injectors is pretty high right?
With the injectors being controlled through the ground and always having power to them... would it be possible to easily run dual injectors simply by adding an extra connector onto the same power/ground circuit? Im pretty sure I could figure it out in the tune if this is a possibility. In theory it sounds like it would work... lol.
Old Dec 24, 2010 | 01:59 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You should not run 2 injectors on the same circuit. This can damage the PCM because it draws double the current on the same injector driver.
Either get an impedance converter for low impedance injectors or run high impedence injectors. Anything else is a disaster waiting to happen.
If you are in need of fuel system components, I'll be glad to get you the correct parts & the proper technical advice you need for your application.
