1998 vapor canister
Old Dec 24, 2010 | 02:23 PM
rv1890's Avatar
Default 1998 vapor canister
My original vapor canister bracket broke off while driving and demolished the canister itself. I bought a used one from Hawks, but now I cant remember how it all goes back together. I have a pic of the canister and the 3 lines that are hanging near the fuel filler neck. Obviously the large hose goes to the large port on the canister, but what about the other two?....One is marked purge and the other is marked tank. The one that says tank has a cap on it....Is that correct...that would leave me with one hose without anywhere to go....
Any suggestions?...or a pic? I couldn't find a diagram of it in the Haynes manual unless i'm not looking good enough
Thank You.
Attached Thumbnails 1998 vapor canister-dscf1782.jpg   1998 vapor canister-dscf1779.jpg
Old Dec 25, 2010 | 05:15 PM
rv1890's Avatar
Does anyone have a suggestion on where I can find this information?.....its causing the check engine light to come on and the car is running rough
Old Dec 27, 2010 | 01:55 PM
rv1890's Avatar
ok cant find the info with the dealer or the manual
At this point seems like im gonna have to pay for a pic from a member on this site....
Can someone please help?
Old Dec 29, 2010 | 10:36 AM
rv1890's Avatar
Don't mean to be a pest, but can someone please help
Old Dec 29, 2010 | 11:29 AM
t/a98's Avatar
Never messed with my charcoal canister before, but the purge line should be the one that goes from the charcoal to the intake manifold, drivers side valve cover should have a black solenoid thing that feeds into the intake manifold. The solenoid is feed from one of the two fuel lines.
So go under your hood and find the line I'm talking about, then follow it all the way back to your canister, then you should be fine...
Old Dec 29, 2010 | 08:09 PM
FrankieD's Avatar
Not sure if this will help you out, but it's a 1999 setup.
Old Dec 30, 2010 | 11:08 AM
rv1890's Avatar
Thanks Frankie, but the 1999 is a different setup....I just cant understand why the "tank" nozzle has a cap on it
Old Dec 30, 2010 | 09:09 PM
FrankieD's Avatar
Try this link:
http://www.compnine.com/index.php?u=...03&grouptype=B
It is a diagram layout of the entire 1998 Fuel system.
Hope that gets you going.
