which fuel pump
Old Dec 26, 2010 | 10:59 AM
bad98ls1camaro's Avatar
Default which fuel pump
my fuel pump is out in my car, autozone has spectra and airtex, i've heard spectra is the better of the two, but will any of these handle the extra fuel i'll need with a tune, headers, ory, intake? or would the walbro be a better bet?
Old Dec 26, 2010 | 01:26 PM
Greekey's Avatar
Do it right the first time. You don't want to spend money on a cheap fuel system and later down the road having to upgrade your fuel system again because your engine isnt getting the fuel it needs. It all depends on your future mods. If your planning on getting heads, cams, etc, in the future then do it right.
Old Dec 26, 2010 | 04:03 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I can set you up with a high performance Racetronix kit that comes complete with hotwire kit for less than you will pay for a parts store pump.
Feel free to call if you would like to discuss your combination.
Old Dec 26, 2010 | 04:30 PM
what do yu mean by do it right the first time? like which one?
Old Dec 26, 2010 | 08:47 PM
Greekey's Avatar
Racetronix
Old Dec 27, 2010 | 12:06 AM
Squirts11's Avatar
Racetronix
I'd pick up the hotwire kit as well.
Old Dec 27, 2010 | 01:46 AM
01ssreda4's Avatar
Racetronix uses the 255 Walbro correct?
Old Dec 27, 2010 | 01:55 AM
00ls1z's Avatar
What about the Bosch 044
 Michael S. Palmer
Old Dec 27, 2010 | 10:52 AM
Nasty N8's Avatar
Racetronix uses a version of the Walbro but it is highly tested and a direct replacement in the factory setup in an FBody.
The Bosch is a huge pump that is not meant for this type of application. And it only slightly outflows a Racetronix setup.
Old Dec 28, 2010 | 09:54 AM
bozzhawg's Avatar
Delco EP381
