Injector upgrade
Plus the injector values are already known for ease of tuning.
what size motor do you have? 6.0 Liter right?
FIC injectors is a sponsor on here. they are good
first of all, check out www.rceng.com or RCEngineering if I cannot post the link. Check out their technical sizing page.
I would recommend 42# rated at 43.5psi (which gives you more breathing room) as you are naturally aspirated and should be under 550RWHP
NATURALLY ASPIRATED.
If i confused you with that lingo, and the pressures & ratings let me know.
I have a set of green top 42lb injectors but was told tuning with them can be a pain, and that I may need an adapter harness and spacers to use them on my stock truck intake. Im pretty new to modding the LS motors, so maybe I am way off base.
