c6 ls2 stock pump limits.
Old Jan 7, 2011 | 01:41 PM
Stang's Bane's Avatar
Default c6 ls2 stock pump limits.
I am on my phone and the search is being homosexual.
Should be around 600 rwhp after the 150 shot.
Will be a wet shot. Do I need to replace the pump, or will a BAP be enough?
Old Jan 7, 2011 | 03:36 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
If it is a Z06, it should be OK with a boost-a-pump.
The standard Vette has a smaller pump & may come up short.
For what it takes to change a pump, you may want to test before you arbitrarily start changing parts.
Get a good pressure gauge & verify the readings so you do not hurt the engine.
Old Jan 7, 2011 | 05:35 PM
Thanks lonnie. I will do that.
