What injector for 415 stroker
Old Jan 9, 2011 | 05:47 PM
Devils Mentor's Avatar
Default What injector for 415 stroker
Looking for some suggestions on what type of injector to run. Looking for ease of tune, lbs, Hi or Low Imped, pintal or disk injectors and 07% - 80% DC.
I am hoping for low to mid 500hp @ the wheel and will be using a Vic Jr setup, Speed Density tune, 2000 ECU.
DM
Old Jan 9, 2011 | 09:34 PM
FICINJECTORS's Avatar
DM
you need to run a 50lb@58psi.this will keep your dc around 75%-80% leaving you some room to grow. you want to stay with a bosch high imp.these are very easy to tune.
http://www.corvetteinjectors.com/sho...p?productid=38
Old Jan 10, 2011 | 04:42 PM
Thanks for the info Bro! One question though... I notice that the info, from the link you provided, states "These flow 50lb/hr in the LS1 Rail"; will they flow the same in an Edelbrock, FAST or the like type fuel rail?
DM
Old Jan 10, 2011 | 05:24 PM
DM
these will flow 50lb in any rail as long as you keep your fuel pressure @58psi.
witch is stock fuel pressure in all 1997 and up ls vehicles.
