Fuel System ???
Old Jan 25, 2011 | 07:03 PM
brian_king25's Avatar
Default Fuel System ???
If it was your 1999 Blown Ta what would you use for a fuel system?
I have head so many pros and cons to everything just looking for some ideal so I only have to do it one time.
402 LS - LS6 Intake, F1a procharger and 8 1/2 to one.
I need Fuel injectors and rails with the system.
ANY HELP?
Old Jan 25, 2011 | 07:16 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
For great streetability, plus being able to support over 1000rwhp, I recommend my dual pump system.
It is quiet, reliable, & you get my tech support with your purchase.
Give me a call & I'll go over everything you need for a complete system, guaranteed to support your goals.
Old Jan 27, 2011 | 04:29 PM
SPDEMON's Avatar
Brain, whats up with the trans? Waiting to hear back from you.
As far as the fuel system, are you going to be using a stock tank/ set-up?
If so, a 255 LPH Walbro plus a in-line piggyback pump should suffice. You will definately need to go with A/M larger capacity lines.
As far as fuel rails, you can pretty much just pick out one of the many A/M brands such as FAST and that should work fine.
Injectors: you're gonna need a minimum of a 63lb/hr but would be better off with a set of #80's, that way you run a lower duty cycle on the injector so its not maxing out frequently.
A set of #80's is good for 1000 hp @ the flywheel with a duty cycle of less than 80 percent. That way if you go bigger (more power) you will have the ability.
