Injector install
Old Jan 26, 2011 | 01:35 PM
mconway68w's Avatar
Default Injector install
I just installed 42lb. injectors and have not yet tuned the PCM. However, I cranked the motor afterwards to make sure everything was done right. It runs terrible and misses bad. Is this normal without a tune?
Old Jan 26, 2011 | 02:08 PM
oange ss's Avatar
yes...
Old Jan 26, 2011 | 02:33 PM
cancam99ss's Avatar
i want to know this tooo...
Old Jan 26, 2011 | 07:04 PM
jattgunman's Avatar
you need a tune, not the stock tune
Old Jan 27, 2011 | 08:56 AM
Old Geezer's Avatar
Flooding it w/ fuel...
Check the oil.. Smell like gas?
Old Feb 3, 2011 | 10:28 AM
JaYZeig's Avatar
with the new injectors, the injector tables are all fubared! new tables will need to be programmed to the pcm to run any type of new/different injector.
Old Feb 24, 2011 | 07:05 PM
jeff keyuk's Avatar
Any new injectors you need to change 4 tables in on your pcm! This is doing the wright way.
