Need help with FPR
Old Feb 7, 2011 | 08:04 PM
SlonomaZ28's Avatar
Default Need help with FPR
My 98 z28 has been blowing out O ring after O ring from the regulator housing. The housing itself is deforming into more of an oval shape and then the o ring blows out the same place at the top of the oval every single time. Anyone else had an issue like this, or have a suggestion? I've been thinking about trying to find some 97-99 corvette rails with the rail mounted FPR but I'm on a tight budget so I'm not sure when it'll be before I could pick up a set.
Thanks in advance, Chris
Old Feb 8, 2011 | 11:42 AM
SlonomaZ28's Avatar
So nobody's had a similar issue, or has any suggestions on the cheapest way to switch to a rail mounted FPR. Car's stock for the moment but will be getting h/c/i in a few months.
Old Feb 8, 2011 | 12:25 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The 98's do seem to have problems with this.
Early Vette rails are getting increasingly hard to find as they have been discontinued for quite a while.
I can set you up with a complete fuel system, but it would be way overkill for your power level.
As an alternate, I could build up a regulator/line assembly to replace the return line from the filter to tank if interested. This would eliminate the intank regulator. A full return system would be better but it depends on what you want to spend.
Give me a call if you want to discuss.
Old Feb 8, 2011 | 10:07 PM
SlonomaZ28's Avatar
I'm on a rather shoestring budget, could you simply recommend a regulator suitable for placement on a return line? I can put together my own lines, but I don't have any experience with aftermarket fuel systems.
Old Feb 9, 2011 | 10:24 AM
Ollie8974's Avatar
For a fuel injection system, select a pressure gauge that is referenced to manifold vacuum and reads to 100 psi.
Old Jan 23, 2012 | 09:30 AM
daves98's Avatar
Why are the 98 hard on fprs mine has ate 4 of them what about getting a sending unit out of 2000 will it solve my problem. dstephenson78@gmail.com plz help
Old Jan 24, 2012 | 12:39 PM
LS1TA_956's Avatar
i am having the same problem in my 98 T/A
