Which Injectors
Old Feb 10, 2011 | 04:17 PM
BTLD_LS1's Avatar
Default Which Injectors
Ok so my 42#'s are being maxed out and Im going to buy injectors tomorrow. Right now Im seeing ~125% duty cycle max out of my injectors. Im looking at going to the 60# or 80# Siemens injectors. I plan on continuing to run E85 in the car full time and might change heads/ stroke the motor in the future, Will the 80's be over kill?
Old Feb 11, 2011 | 01:21 PM
RX-Matt's Avatar
It really depends on what your HP goals are in the future. How much HP do you plan on making? And if you are going to wait a long time to bore/stroke and add a lot more power, I would recommend just getting the 60's, plus on an NA motor 60's will take you a long way, even on E85.
Here is a link to our Siemens 60#'s
http://www.racetronix.biz/itemdesc.a...114961&eq=&Tp=
And Siemens 80#
http://www.racetronix.biz/itemdesc.a...114992&eq=&Tp=
Old Feb 12, 2011 | 03:54 PM
parks450's Avatar
60's will be fine for now. 80's definately overkill for you right now, if its gona be awhile before you do all that get 60's now and sell them at that point. Youll get most of your money back anyways.
Old Feb 13, 2011 | 08:57 AM
BTLD_LS1's Avatar
I ordered 60's Friday thanks for the replies tho
Old Feb 13, 2011 | 10:37 AM
20TA02's Avatar
i have the Siemens 60#'s and glad i went with them... my tuner is also glad i went with those because he dialed them in pretty easily...
