Return style vs. Returnless?
Old Feb 15, 2011 | 09:19 PM
Dirty Vegas's Avatar
Default Return style vs. Returnless?
Ok, I have a 99 Camaro V6 body with an LS1 swapped in. I've been running the corvette filter/regulator combo for the past season with less than stellar results. I recently ordered a Fuelab regulator, to make my fuel system more reliable. However, the supplier sent me a returnless regulator, instead of the bottom return like I had ordered. So my question is, should I run returnless, like most other LS1's, or is there an advantage to running a return?
Old Feb 15, 2011 | 09:59 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
There is no such thing as a returnless EFI regulator. That would in most cases burn up the fuel pump.
Likely what you have is a 2 port regulator... 1 side is an inlet, the other a return. What do the directions say?
Old Feb 15, 2011 | 10:14 PM
2 port like you said. So I would need a 3 port?
Old Feb 16, 2011 | 08:48 AM
LS1TECH Sponsor
The 2 port should work (it is just a different style), but you need to work out the details with the people you bought it from.
Old Feb 16, 2011 | 09:49 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The 3 port would give you more plumbing options, but the 2 port will probably work just fine. Mine is a 3 port, but only two are used (one side port and the bottom return port). I switched to an up front regulator system due to the variations in pressure I was seeing with the stock, in-tank regulator. It wasn't cheap to do, but it works very well.
Old Feb 16, 2011 | 11:34 PM
Thanks, my pressure is all over the place because of the V6 system.
Old Mar 10, 2011 | 11:20 AM
BlackBirdDaddy's Avatar
I'm just wondering what problems you were encountering and why the Corvette filter/regulator would not work? Did your upgrade you fuel pump?
I am in the middle of my LS2 conversion into a 2000 3.8 Firebird. I upgraded to a Racetronix FPA-001 pump and was going to use the Corvette filter/regulator to make a cleaner look of the plumbing system and eliminate the T-fuel block for my return line.
Has anyone else done this type of set-up with success?
Thanks,
Jim
