When do you need larger injectors?
The issue is getting improper fueling. If you have an injector that is giving you consistent fuel delivery, then why not, sure.
"Most injectors will operate up to 80-85% duty cycle without any issues. Exceeding the maximum duty cycle will basically cause the injector to go static. The transition from a dynamic state to a static one will cause the injector to become unstable for a brief moment. Typically, the injector pulse width will operate past this "dead zone" rather quickly and go wide open. "
