Help with building 6AN feed line.
I searched on thunder racing but I'm not finding much. I'll check Jegs while I'm at it. The cross over is a -8, btw.
-=edit=-
Just check this stuff over for me.
Found the 90 I needed through Jegs.
http://www.jegs.com/i/JEGS-Performan...oductId=830891
Would this work?? (quick disconnect)
http://www.jegs.com/i/Aeromotive/027...rentProductId=
For reference; This is the feed line I'm looking to replace. Pretty sure it's a dash 6.
I'd also personally recommend you think about using a teflon core line instead of the synthetic rubber core braided line most use...over time, the additives in the fuel will break the rubber down and the line will start allowing fumes to pass into the atmosphere. There's another thread in here that already talks about that a few posts down from this one.
I'd like to support the local guy.
I really appreciate the time and advice guys. Didn't mean to post a BS thread, but I thought of that shop after I posted this.
But were here when you need us.
Graham @ N20
