Unhook fuel line from rail
Old Mar 5, 2011 | 04:03 PM
vintageracer's Avatar
Default Unhook fuel line from rail
How does the fuel line unhook from the fuel rail? Does it use a tool like Ford uses for A/C lines on their cars or other unique tool?
How does the evap return line unhook from the plastic housing mounted on the intake?
I know should be simple knowledge. I tried to search the site first with no luck.
This is my first LS engine removal from a 2000 Camaro.
Thanks for the assistance!
Old Mar 5, 2011 | 04:31 PM
Old Geezer's Avatar
Quik disconnects like the Ford`.. U can get a cheap set of tools at most a/p stores..
Old Mar 5, 2011 | 05:46 PM
Thank you for the response.
That's what it looked like to me. It was time for a break so I thought I would ask. I'll be back out in the shop tonight and disconnect.
I am still I am not sure how to disconnect the Evap line. It has a plastic connection to a plastic valve on the intake. Any suggestions? Does it also use the tool like the fuel line? It looks different.
Old Mar 5, 2011 | 06:01 PM
MeentSS02's Avatar
Kleeborp the Moderator™
It looks different, but is the same basic design. It's been a while since I unhooked the EVAP solenoid from the manifold, but there may be some sort of clip that you have to remove before you can take it off.
