Fuel System Upgrade
Old Mar 7, 2011 | 11:11 PM
sprayn_z's Avatar
Default Fuel System Upgrade
97 camaro with a 383 going to spray the car with atleast 150shot... just curious if anybody has had any luck with keeping the factory fuel system on the lt-1s or would a fuel system upgrade be a wise thing to go ahead do while im in the build... i might get a wild hair to up the shot later too... if some has went with an upgrade.. what did you go with and what seemed to work the best.... thanks for the help
Old Mar 8, 2011 | 07:00 AM
ZL1Killa's Avatar
wet or dry shot?
You will need a fuel upgrade for that. Talk to Lonnie, lonnies performance
http://www.lonniesperformance.com/
Old Mar 8, 2011 | 01:26 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Thanks for the referral.
As for the LT-1... they have a front mount regulator system that workes very well into the 750rwhp range.
As for pumps, I offer a single Racretronix kit that should easily support 550rwhp, or one of my dual pump kits from there up, into the 1000rwhp range.
Feel free to call if you want to discuss in more detail.
Old Mar 8, 2011 | 05:41 PM
sprayn_z's Avatar
its a wet shot... alright ill give ya a call in a couple days... thanks for everyones help
Old Mar 8, 2011 | 11:20 PM
madmax4499's Avatar
I need this set up as well. i cant decide if i should go with the LS3 manifold or a carb/efi manifold with an elbow and TB is one proven to make more power. mine is twin turbo.
Old Mar 9, 2011 | 08:23 PM
LS1TECH Sponsor
The original post was relating to a LT1 application, which is very different than your LS based one. Feel free to give me a call if you want to discuss your application.
