Tick tick
Old Mar 16, 2011 | 06:19 PM
nasteeZ28's Avatar
Default Tick tick
I have finally pinpointed my ticking noise and it is coming diretcly from the fuel rails on both sides ... does this mean i have a bad injector or something? the noise doesn't seem to come from either side.. am i going to have to just deal with the ticking or should i try harder to pinpoint a single injector?? this drives me crazy when i drive by a fence or a drive thru.. any suggestions?
Old Mar 16, 2011 | 07:10 PM
nasteeZ28's Avatar
does anyone else have a similar ticking? sounds smooth when cold but the tick starts after warm up.. i cant hear it on the inside of the car, only when the noise reflects off something else
Old Mar 18, 2011 | 08:14 PM
jim ravencraft's Avatar
Hi,
check ohms reading 11-14 resistance ok.......use stethoscope they should click steadly with an increase/decrease as engine rpm's go up/down..you can also use the noid light it should blink on cranking mode or with engine running.
I hope this helps.........have a blessed weekend.......captain jim
Old Mar 18, 2011 | 09:28 PM
madmax4499's Avatar
some vehicles just have loud injectors, Normal, you should hear my EVO
Old Mar 19, 2011 | 05:39 PM
nasteeZ28's Avatar
would it make sense if the they didn't start ticking until the engine warms up??
Originally Posted by jim ravencraft
Hi,
check the ohms on what? i used a stethoscope and they do click steadily as rpms increase and decrease
