fuel for 700 n/a at the crank
Old Mar 22, 2011 | 08:37 AM
Z500HP's Avatar
Default fuel for 700 n/a at the crank
I was wondering what would be the most economical way to do a fuel setup for 700 n/a at the crank. what would be a average cost? ty.
Old Mar 22, 2011 | 07:22 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Depends on the application.
A single pump 255lph should support near that power level.
Old Mar 22, 2011 | 08:32 PM
Z500HP's Avatar
What do you mean depending on the aplication? I would want something that would be a little more than I need just to be cautious.
Old Mar 22, 2011 | 08:49 PM
LS1TECH Sponsor
Your 1 sentence post does not specify the year or model of the car, the engine size, or the fuel pressure you intend to run. It is hard to gve a specific answer with no info.
Please add your vehicle info to your signature so people know what you are working on.
Old Mar 23, 2011 | 08:25 PM
Z500HP's Avatar
sorry about that. Its a 98 camaro with a board and stroked LSX block. I was going to go with a 427 but maybe bump it up to somewhere around 440 or 450 cubic inch. If I have been ready rigt I have a metal gas tank since my camaro is a 98. I read about the new 340 intank pump from aeromotive and the 044 & 413 from bosh and the jayracing pro-series 044. I will be getting the gmpp or victor jr for my ls3 heads and a accufab 4150. I also have 60lbs bosh injectors, they are the small type not the long ones. I would like to do it as simple as possible. Hope that helps.
Im still looking for the easiest and most economnical way to feed 700 n/a at the crank. ty
Old Mar 27, 2011 | 06:40 PM
LilJayV10's Avatar
What's a board and stroked motor?
Old Mar 28, 2011 | 12:15 AM
Z500HP's Avatar
If youre going to be a jerk then take it somewhere else because Im here to learn about lsx motors and 4th gens.
Originally Posted by Z500HP
sorry about that. Its a 98 camaro with a bored and stroked LSX block. I was going to go with a 427 but maybe bump it up to somewhere around 440 or 450 cubic inch. If I have been ready rigt I have a metal gas tank since my camaro is a 98. I read about the new 340 intank pump from aeromotive and the 044 & 413 from bosh and the jayracing pro-series 044. I will be getting the gmpp or victor jr for my ls3 heads and a accufab 4150. I also have 60lbs bosh injectors, they are the small type not the long ones. I would like to do it as simple as possible. Hope that helps.
where did you go?
And for the judgmental jerks, I fixed my spelling
Old Mar 28, 2011 | 06:24 PM
LS1TECH Sponsor
You are on the ragged edge of a single Walbro with 700 flywheel, but it should work. The 044 will likely handle a little more power as will the others.
You will need additional wiring & sending unit mods to run the larger pumps due to the heavier current draw.
Feel free to give me a call if you want to discuss in more detail.
Old Mar 28, 2011 | 06:42 PM
Z500HP's Avatar
Thank you for the information Lonnies.
yeah I was wanting to do a singlesince I figured that it would be the easiest and most economical way. Will the new Aeromotive 340 work as a single in tank pump for my power levels?
thank you again.
ok now I am a little confused. I thought the 044 and 413 were in tank pumps, but now I just read an ad for a 044 and it was a external pump.
Old Mar 28, 2011 | 08:25 PM
LilJayV10's Avatar
sorry man. You need some thicker skin to hang out around here.
Good luck with your build. Lonnies stuff is top notch.
Old Mar 28, 2011 | 08:53 PM
Gordon0652's Avatar
I'll be using Lonnies dual 255 system with my set up in my sig. I like to believe it's more than 700hp at the crank.
Old Mar 28, 2011 | 09:00 PM
Z500HP's Avatar
Its ok I just thought you were trying to be a jerk.
what is the average cost of a system like this? TY
Old Mar 28, 2011 | 09:04 PM
Gordon0652's Avatar
You'll have to talk to him, he replied in this thread, PM him or call. Awesome guy.
EDIT: it says you can call up to 11:00pm EST and he means it - call him tonight.
Old Apr 8, 2011 | 02:20 AM
Z500HP's Avatar
Yeah I will be contacting them soon. Thanks!
