Any special
Old Apr 1, 2011 | 09:14 AM
Sweet_SS's Avatar
Default Any special
tools needed to swap out injectors on an LS1? Sorry if this is the wrong section for this question. I'm going to be installing mine this weekend and didn't want to run into any issues.
Thanks.
Old Apr 1, 2011 | 10:01 AM
Tirefire's Avatar
No, just pop them right out. Make sure you lube the O-ring before you install the new ones so that they make a good seal.
Old Apr 1, 2011 | 10:09 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Not really...just need to unbolt the fuel rail from the intake manifold. You can probably even leave the feed line attached, but make sure you relieve any pressure still in the rails with the Schrader valve. As long as you don't mind getting fuel stank on you, it is pretty straightforward.
