Does anyone make a jet/venturi pump?
Andy
http://www.demaeng.com/product.php?id=74&catid=28
we use them to inject soap into a pressure washer line. I think I had the same thought you did. I am going to try it this week.
Not trying to be rude, but that's exactly what he said he didn't want.
I think I get what he's driving at though. He wants to run a bigger, or series of intake pumps. Like maybe the new aeromotive 340 stealth pump?
and build his own venturi system and custom fuel pump bucket to put it all in.
This would be a really slick set up, but I'm not sure if you'll have all the bits you need.
Is there any reason you can't scavenge the ventrui system out of a existing fuel sender? Or do you want something with more capacity?
As long as he feeds pressure to that bit you posted Greg, and regulates it carefully, he can use what you used as the soap feed to scavange the bottom of his tank, and then that fuel and the fuel being used to suck it up would be dumped into the top of the fuel pump bucket... So his in tank pump is always submerged.
So make a custom sender with one big pump, or two equal size pumps or one big and one little pump (using the little one to run the venturi)
Regulate some pressurized flow to that venturi pump from the main feed of the main pump by using a fitting with a small orifice on it... then run the pick up to under the whole assembly (with it's own filter), then dump the output into the fuel bucket. done.
I wonder how much pressure you loose at the fuel rail though (probably not enough to notice)? Would it be better to just use a stock sender to feed a small fuel cell with a big pump attached that feeds the fuel rail?
