Magnafuel pump question!
Insulate fuel tank/cell and lines from any heat sources
2 x -8 vents
-12 inlet with 7006 prefilter
Magnafuel ProTuner pump (usually 750's because the cost is so close for all of them)
-10 feed with 7008 filter
9950 regulator
-10 return with 11"X8.5"X1.5" plate style cooler
return fuel to corner of tank/cell furthest from the sump/pick-up
Alot of people don't spend the money and effort to set them up this way.
But, it keeps us from having issues like the OP's.
2 x -8 vents
9950 regulator
I've never measured the temp on the return side, but we've never had a heat issue with that set-up. Alot of people consider it overkill, but I'd rather have overkill than problems.
