Dual Pump System for 2011 Camaro SS
"the fuel pumps supplied with the XXXXXX twin fuel pump kit are designed for use with pulse width modulated control systems like the 2010-2011 Camaro. For durability reasons XXXXXX does not recommend using the TI/Walbro gerotor type GSS pumps or other pumps not designed and tested for use in pulse width modulated applications."
I am looking for a little clarification on what this means and whether or not it is a legitimate concern.
Lastly, how about a group purchase?
Thanks,
Mike
Very interesting.
You guys want to borrow my car for a couple of weeks? All you have to do is leave the system installed when you give it back.
The use of a non-pulse width modulated pump in this application may cause pump damage.
Also trying to eliminate the pulse width modulation feature is not preferred as you will need additional items for proper fuel pressure control.
I have a drop in dual pump setup for the 2010-2011 Camaro. It is designed specifically for pulse width modulated applications. These are in stock.
Feel free to call for more info.
Lonnie,
I noticed you offer the pump kit with or without the lines and fittings. This seems to point to a limitation in the OEM lines. What are the limitations of the OEM lines if you don't mind me asking?
You can add an external regulator, but it requires special mods to the fuel system in addition to careful coordination with the factory pump controller so they do not fight each other, or cause the pump to run at full output all the time which will likely kill it.
My dual pump kit has already supported over 900rwhp, using the factory controller & regulator. We also have you covered if planning on higher power levels with my triple setup.
