please help
Old Apr 15, 2011 | 11:07 PM
Travose21's Avatar
Default please help
My fuel pump is not Commin on. I have a 255 walbaro with racetronix hot wire kit. I here the relays clicking so I'm assuming I'm getting connection but pump is not primeing or Commin on when I spin it can someone give me pointers
Old Apr 16, 2011 | 05:33 AM
Travose21's Avatar
Anyone please help
Old Apr 16, 2011 | 07:34 AM
Old Geezer's Avatar
Assuming will get you zip..
New install?
Verify the operation and output of the relay. Just because it "cliks" doesn't mean it's working on the power out side.
Verify the presence of power at the pump.
Check all the grounds.
Old Apr 16, 2011 | 09:55 AM
crainholio's Avatar
Originally Posted by Travose21
Anyone please help
Whip out your meter and probe the fuel tank connector for 12VDC coming from the relay.
Then probe the ground for continuity (set meter to Ohms, should read infinity or near-zero resistance with the other probe on any good chassis metal point.)
If these two tests pass, time to drop the tank and remove/inspect the pump.
Old Apr 26, 2011 | 10:26 PM
69TA's Avatar
Travis,
Sent you a pm and emails about the parts
still waiting on you to take of everything.
