Injectors will not fire!
Old Apr 16, 2011 | 07:38 PM
DRTHVDR's Avatar
Default Injectors will not fire!
I tested EVERY possible thing that could be wrong:
The injectors have 12V,
the fuel rail has 60 psi,
car runs on starter fluid,
injectors are NOT firing when cranking the car,
the injectors work with a constant 12V power source,
the crank position sensor wires work and are not shorted out,
everything is working except the injectors.
Does anyone have ANY Idea why the injectors not firing?
Old Apr 16, 2011 | 09:10 PM
squarehead's Avatar
was the wiring altered?
sounds like one of two things
you do not have 12v at the injectors with the key in the start position. I assume you are seeing 12V at the injectors with the key in the on position
or the ECM is not providing a ground to activate each injector
Old Apr 16, 2011 | 09:15 PM
DRTHVDR's Avatar
I have 12v at the injectors, I checked.
The ecu is not providing ground.
What could be the cause of that?
Old Apr 16, 2011 | 10:26 PM
squarehead's Avatar
Do you have 12V when cranking or when the key is held in the start position?
It is possible to have 12V at the injectors with the key on and not have 12V with the key in the start/cranking position. Those key positions are 2 different voltage sources.
The injectors have 12V supplied to them and the ECU provides the ground to turn on each injector. A cause for this (no ground) could be a bad ECU.
Old Apr 17, 2011 | 06:36 AM
DRTHVDR's Avatar
I swapped an LS3 intake manifold and injectors on my L92.
Could that be an issue?
Are one of the injectors high impedance and the other low impedance?
Old Apr 17, 2011 | 10:35 PM
Slo_240sx's Avatar
Give us some history on the vehicle... Which PCM and are you running? You are using a L92 engine, correct? Had the engine ran before up until you swapped the intake manifold?
You say that your crank position sensor is working well, the injectors drivers receive their signal from the camshaft sensor. Confirm that the CAMSHAFT position sensor had 12v and a ground, as well as continuity from the sensor to the PCM itself.
Also how are you checking the ground from the injector driver (pulsewidth)? Are you using noid lights? If you are using a multimeter or test light, the signal is too fast to be caught on a multimeter though a test light will pick it up and will be faint flicker.
Old Apr 18, 2011 | 03:03 PM
DRTHVDR's Avatar
I'm still using the stock L92 computer that has been flashed to remove emissions and VATS.
I don't have a noid light that could test pulse width.
Old Apr 18, 2011 | 07:10 PM
Slo_240sx's Avatar
Did the engine run before you swap the intake?
How are you checking the ground signal? With a test light? You can buy noids lights at the parts store though they are expensive. See if you can borrow a set from someone.
Old Apr 18, 2011 | 07:35 PM
BelAir1000's Avatar
I was gonna say...the ECU probably supplies battery voltage until it switches to ground to fire the injector(i.e. battery voltage to both pins)....someone correct me if I'm wrong. So the 12V your measuring may be FROM the ECU not from the power supply. Disconnect the injector connector and check boths pins with key on.
Old Apr 19, 2011 | 08:19 AM
DRTHVDR's Avatar
I did that BelAir.
They have 12v with key on and 9v with the car cranking.
Old Apr 21, 2011 | 08:19 PM
DRTHVDR's Avatar
Okay...the noid light blinks at first and then goes out after a second.
Plugged in an 07 truck ecu and it's not firing. I'm trying a stock L92 ecu tomorrow.
Slo 240sx: The crank position sensor is checking out okay.
Old May 16, 2011 | 06:46 AM
DRTHVDR's Avatar
Anyone that cares....it ended up being the VATS wasn't completely turned off. HP Tuners (2 different versions) said it was off but when I sent it to Speartech (props to John) they found that it wasn't completely turned off. Do they use Tech II (2)? Anyway, he turned off VATS and the car started right up. A month of trouble shooting and it was just a click of the mouse.
Old Oct 7, 2012 | 04:02 PM
Fastcayman's Avatar
Default fastcayman
Hi Guys,
Further to your findings, I also had a similar problem. the fuel pump was changed, all grounds checked, swapped the computer, but injectors would not fire. so I lifted the intake, replaced the camsensor and also changed out the injectors and bingo.
My theory, these cars are 12 to fourteen yrs old. and yet a lot of them are still running the original fuel pump and injectors. if the sit unsued for a while chances are somthing will likely quit. I'm pretty sure the injectors were stuck so just my farthen worth.
hope it helps,
Hansen
Old Jan 4, 2015 | 12:19 AM
Gaspo's Avatar
i have the same issue i think but only bank 2 of my car isn't firing. any ideas?!
Old Aug 28, 2016 | 12:26 PM
tukn20's Avatar
Need help Engine is 1999 5.3 with 4L60e Been done for 6 years Has spark, good fuel pressure and fuel pump is working It just started this issue It runs and they it won't start it's like it's getting heat soaked. Now the injectors aren't pulsing. Just check all the grounds and power in the harness all ok
on the injector with the key on we have 12v on one side but not the other
We just drove and and started it and it set for 10 min and won't start again
Old Aug 28, 2016 | 12:34 PM
tukn20's Avatar
