Injectors not opening at 60psi...?
The injectors will not fire at 60 psi, but if i turn down the pressure til 43 psi they work fine. The injectors are Delphi 50 lb high impedance, ECM and wiring harness is from a 1999 LS1 Camaro. Trying to tune with HpTuners.
The only thing that comes to mind is a voltage issue at the injectors so there is not enough "power" to overcome the pressure?? Any thoughts???
I have not been able to measure the voltage because the engine is a friend of mine's and he is quite far away from me...
This is a custom install of LS1 electronics on an GenI engine (using the EFI Connection reluctor kit).
Any input is appreciated!!
I chased this problem for weeks on the dyno before we figured out that they were the injectors.
I had the EXACT same injector as you. Theres nothing wrong with them, just not made to go up to that pressure. hope that helps!
Maybe some of the vendors have some info on this?
The coils are just not designed to pull up the pintle against the Higher pressure
www.youtube.com/watch?v=qgepPxF0Af0
