How much injector is needed
Old Apr 25, 2011 | 04:06 PM
speedracer2536's Avatar
Default How much injector is needed
a forged 355 lt1.. le2 heads 11.3:1 compression cc306 cam stock intake stock throttlebody 6speed. Will be hit with a 250 shot wet kit from time to time..
Old Apr 25, 2011 | 04:12 PM
btw i already have a walboro255 and the hotwire kit
Old Apr 25, 2011 | 04:34 PM
02_camaroz28's Avatar
(Estimated HP) x (BSFC) / # of cylinders x Max Duty Cycle
Example- (600 HP) x .6 / 8 x .80= 36lb per hour @ 43.5 PSI
(Brake Specific Fuel Consumption)BSFC= Pounds of fuel burned to support 1HP for 1 hour. Gasoline Engines will typically be between .4 -.7 depending on how efficient the engine is.
Standard Injectors are Tested at 43.5 psi
Old Apr 25, 2011 | 07:54 PM
ZL1Killa's Avatar
36# or 42# will be fine. if you plan for future mods I would just get 42#
the wet kit will be nice. with the power you will make i would go ahead and get 42#
Old Apr 26, 2011 | 07:26 AM
Thats what i was thinking.. Thanks for the heads up.. i was starting to look at 30#.. LOL
Old Apr 26, 2011 | 08:55 PM
ZL1Killa's Avatar
oh no no. the stock ones are 28.8#
Old May 11, 2011 | 10:09 AM
stock ones are actually 24#.. Its for lt1
Old May 11, 2011 | 02:34 PM
deatschwerks's Avatar
We have a few fuel calculators on our website you can use to play around with different power goals, fuels, system pressures, etc.
http://www.deatschwerks.com/fuel-calculators/
Looks like a 42# would be a good size for what you are looking to do on spray.
