Running Stock Pump WITH Walbro
Old Apr 28, 2011 | 02:33 PM
RedVertTA's Avatar
Default Running Stock Pump WITH Walbro
A lot of you guys are running dual walbros in the fbody. Does anyone know if it would be possible to run a walbro and a stock pump in the same bucket? That way the stock venturi system would still fill the bucket.
Old Apr 28, 2011 | 06:52 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
There is not enough room in the sender for 2 pumps & the venturi setup.
Old Apr 29, 2011 | 10:14 AM
RedVertTA's Avatar
Ok, what if an intank pump smaller than the 255 was used? Like some type of stock replacement pump.
Old Apr 29, 2011 | 10:24 AM
LS1TECH Sponsor
Look at the pumps available. They do not get much smaller in size.
Old Apr 30, 2011 | 09:17 PM
02SOMLS1WS6's Avatar
What is the down side of not having the venturi design in the dual pump set ups?
Old May 8, 2011 | 09:53 PM
RedVertTA's Avatar
^^^ Not being able to run less than 1/4 tank, fuel pressure stalling if fuel sloshes around in the tank.
