Larger Injectors &/or Pump Needed for This Setup?
Do I need to upgrade to larger injectors &/or a 255 pump? I do plan to install NOS some time down the road - but not now (if my stockers are borderline with the setup mentioned above I would like to upgrade now if tuning will be possible using larger injectors at this time prior to NOS).
If larger injectors are recommended what size should I go with and mfg.? I need info from the experts
or someone that has a similar setup.I will be getting these installed along with a dyno tune @ Rapid Motorsports and would like to have them in advance if needed.
TIA,
-Jay-
