What is this ?
Old Jun 8, 2011 | 09:51 PM
"Grabby" 2000Z28's Avatar
Default What is this ?
I thought it was a pressure regulator but the manual says that is in the tank .
When I change fuel rails there is nothing that will be affected by not having "this" on the crossover ?
Old Jun 8, 2011 | 11:53 PM
NBM-LS1's Avatar
Fuel pump pulse dampener.
Old Jun 9, 2011 | 05:43 PM
Default Nbm ls-1
thank you for the response . I see you have gone to FAST intake and rails . So its OK to delete this device ? It's like the spring on the clutch pedal , no apparent function ? Thanks again !
Old Jun 10, 2011 | 07:42 PM
NBM-LS1's Avatar
I need to update that. I run an ls6 with aftermarket rails. if your fuel system is after market you dont have or need irt
