injector help
Old Jul 9, 2011 | 01:04 AM
victorls1's Avatar
Default injector help
i have a 2000 camaro cam only was fi.i have a set of motron 60lb injectors
that i sent to fic.they rebuild them and then flow them to 80.5 at 43.5 psi
my question is do i need to run them at 60psi or 43.5.
thanks
Old Jul 9, 2011 | 09:05 AM
FICINJECTORS's Avatar
thanks
If you run them at 43.5 they will be 80lbs. At 60 psi you need to scale the IFR to 92lbs
Old Jul 10, 2011 | 09:39 PM
ZL1Killa's Avatar
uummm... you say was FI and you are now using them on it, naturally aspirated...damn.
