Disconnecting Filler Hose?
Round 2 of fitting a square peg through a round hole is today after work.
You have to lift up the housing, and gently pull it out. The bucket is nearly the same diameter as the opening, so a small falt tip screwdriver can be used to slip it out, but don't pull it all the way out. The fuel level sender is attatched and the hole sender unit needs to be tilted slightly to get it out.
FYI, I just started a new thread to try and solve the priming/fuel pressure issue. https://ls1tech.com/forums/fueling-i...help-pics.html
