Any Idea on injector size for 410lt1
Old Jul 28, 2011 | 02:51 PM
410strokerss's Avatar
Default Any Idea on injector size for 410lt1
I want your guys opinion on a good injector to use with my 410 stroker build.. its got max ported trick flow heads..hogged out lt1intake and 58mm tb..
Old Jul 29, 2011 | 11:14 AM
deatschwerks's Avatar
As far as injectors go, you just need to know what kind of power the engine will be producing and the base fuel pressure you'll be running.
We have a fuel calculator on our page if you'd like to play with some numbers - www.deatschwerks.com/fuel-calculators
35# injectors in a 3 bar fuel system should be able to support 525hp N/A, and keep the IDCs in the 80% range.
35# injectors in a 4 bar fuel system would be around 600hp N/A.
Old Jul 31, 2011 | 06:27 AM
i think ive got a good idea now what route im going...thanks for your time and helpful info
