Help with fuel line ends
Old Aug 8, 2011 | 07:36 PM
FatfreeGTO's Avatar
Default Help with fuel line ends
I ordered a prebent stainless 3/8" fuel line for my 66 GTO, now that I'm doing an LS swap I have a question about the ends on this line. I don't have a picture handy but it looks like this only difference is where it builds away from the line there isn't an angle its a perfect 90, but this was the closet thing I could find
Is there a way that I can adapt to AN fittings for this type of end or do I need to do something else?
Thanks alot!!
Old Aug 8, 2011 | 07:50 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you talking about a standard SAE J2044 style fitting (factory push-connect)?
Old Aug 8, 2011 | 08:02 PM
FatfreeGTO's Avatar
No I don't think so. The end of the line has this "bulb" for a better word at the end of it. I think its on there simply to prevent the old rubber line from backing off of the stainless line. I will probably have to get a picture.
Old Aug 8, 2011 | 08:35 PM
MeentSS02's Avatar
A picture would help...is it just beaded like a fitting on a radiator would be?
Old Aug 8, 2011 | 08:36 PM
FatfreeGTO's Avatar
These pics show the end of the fuel line. What can I do to connect up to the LY6 truck intake fuel line?
Old Aug 8, 2011 | 09:26 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You would need to cut that end off. Then get a AN nut & sleeve to put on the end of the line & reflare. This will allow you to run an AN braided line to the engine from there.
Old Aug 8, 2011 | 09:34 PM
FatfreeGTO's Avatar
Thanks for the info. That line was installed with the body off the car and it was even hard to do then. I only have 1" of line sticking out of that hole something tells me this is going to be a project.
