Edelbrock Question
Old Aug 21, 2011 | 08:31 PM
98SLPss's Avatar
Default Edelbrock Question
Do you have to run a fuel pressure regulator with the Edelbrock style intake system?
Old Aug 21, 2011 | 10:03 PM
67RSCamaroVette's Avatar
Yes, you have to run a fuel pressure regulator. No, you don't have to use an aftermarket one. The stock one works fine assuming you aren't using a ridiculous amount of pump. Simply get a Russel fuel line adapter (the new thread-retained one is 644120) and use some -6 hose from the factory hard line (next to your ABS block) to your rails. The thread size on the Edelbrock rails is 3/8 NPT, so you'll need some -6 to 3/8npt adapters. (660460 or 660840 for a 90 degree) You shouldn't need more than 4 feet of -6 hose total. You will need one 3/8 NPT plug as well when using it as a returnless rail.
Old Aug 21, 2011 | 10:26 PM
98SLPss's Avatar
You are the man! Thanks
