Help!! 42 vs 28# injectors
Any idea if his car being tuned for 42s would make a 3 hour drive with the 28s to the dealer? Also would my car be ok running on the 42s until I have the tune updated? - I rarely drive it anyway (maybe 100 miles a month). I just like to get it out and beat on it every once in a while.
Thanks,
You might be safe in closed loop. It will certainly be rich. I would be a bit more worried about him though. Stay out of PE if you plan on doing this.
This is also a worst case, the ideal plan is to pull mine tonight and let him swap them out over there tomorrow.
Vats should still work on both cars since it is a function of the BCM, which would remain in each car, as is.
Edit: I've just read that your friend is driving to the dealer today.
