Where to pull fuel for nitrous from
10AN Feed Line -> 10AN to Dual 8AN Y-Fitting -> Dual 8AN Lines to Fuel Rails -> Dual 8AN Lines out of Rails to Single Regulator -> 8AN Return Line
I was thinking after the rails and before the regulator, but I'm afraid if I pull from one side it would create an imbalance between the two rails. Is this true? Would it be better to pull from the the 10AN Feed Line right before the Y-Fitting?
