need more fuel ???????
Old Feb 1, 2012 | 01:07 AM
caddy03pimpin's Avatar
Default need more fuel ???????
Sup guys want to check in to other options and see what else is out there . My fuel system is screaming for mercy , I have kb bap , walbro 255 in the tank, I got 60lbs injectors my idc is very high , so its time to step it up . My truck right now has the returnless setup could I get away with just dropping a walbro 400 or do I need to make my system return ,I really don't want to do a dual pump setup
Old Feb 21, 2012 | 06:35 PM
slippi84's Avatar
How much power are you making now or what are you running that your maxing out that setup just curious as I have a KB BAP and 65lb injectors and I'm wondering what the limit is with this setup
Old Feb 22, 2012 | 12:01 PM
I'm running a 408 and a 2.8 kennebell @ 10 lbs with supporting buttons , I just bought the walbro 400 ill be installing it in the next week or two and see if its up to the task. I will also be switching over to return style setup , as far as hp man I don't know lol the truck is allwheel drive and haven't put it on the dyno rough est. 650 I know there is alot more in it but I hit a wall with not having the enough fuel, there is a guy that used dual stock pumps and a bap and was able to support 900 HP
