Basic Walbro 255l wiring diagram question
Old Feb 4, 2012 | 11:57 AM
NovaKid's Avatar
Default Basic Walbro 255l wiring diagram question
I did a search and found this wiring diagram on another website for a different fuel pump. Is this correct for the inline Walbro 255l and will the bosch relay 0-332-204-150 work? Thanks guys.
Old Feb 4, 2012 | 09:48 PM
NovaKid's Avatar
bumpp
Old Feb 4, 2012 | 10:15 PM
got-a-ls1's Avatar
that is a basic diagram that will work no problem. however if you want to take advantage of heavier gauge wire to run the pump then you must replace the internal wiring as well. I did twin pumps on my tank and drilled through the top of the sending unit and ran TEFLON coated wire into the sending unit and sealed it in with epoxy. if your only running a single pump just get the racetronix setup. its really the best option.
Old Feb 6, 2012 | 11:56 PM
NovaKid's Avatar
Cool cool, thanks for the info
