need help/advice
your stock 190L/hr pump will suffice for your 30LB injectors.
and when you tune it for those 30LB injectors, you will want to make sure you tune the IFR table correctly for what those things are rated for with regards to their ratings and your actual fuel pressure.
for instance, 30LB red top SVO injectors are likely rated that at 43.5psi
you will be running 58psi roughly on them...
this makes them the equivalent of sqrt(58/43.5)*30 = 34.64LB/hr at your fuel pressure
compared to the max 38LB/hr of the stock pump you are good.
any more fuel questions, PM me.
You should only need to upgrade to a larger pump and injectors when you add some forced induction or go for some serious mods above 480rwhp NA
