Stock LS3 fuel rails with -8 An's welded on. Questions
Old 02-20-2012, 10:56 PM
tonyturbo42's Avatar
Default Stock LS3 fuel rails with -8 An's welded on. Questions
Just bout an LS3 with a stock set up almost exactly like this. Seems like a hassle to run dual feed lines instead of just one feed a cross over and a return out of the reg. Its s TT set up going into a 67 El - Camino. Anyone got any advice on if should stick with this set up or just get an easier to plumb aftermarket set up. Advantages / Disadvantages.
Thanks Tony
Old 02-20-2012, 11:07 PM
97badass's Avatar
You could have flipped the fuel rails for a cleaner install. Other than that I have no clue
Old 02-21-2012, 12:01 PM
blu00rdstr's Avatar
That pic was of a Vette I had built, wrecked and sold. The 75lb RC injectors raised the rails and the AN fittings hit the firewall.
Old 02-21-2012, 02:06 PM
11 Second Truck Club
L-EATER's Avatar
What are the stock rails made out of....Stainless?? I am building a combo right now using a LS3 manifold and injectors, and really like the stealthinesss of the stock rails but I need a return. It would be great if I could just weld some fittings to the stock rail!
Old 01-08-2013, 06:39 AM
baggins's Avatar
where do you get the weld on -8 fittings?
Quick Reply: Stock LS3 fuel rails with -8 An's welded on. Questions
