fuel pump wiring.
Old Feb 23, 2012 | 02:30 PM
98chevyz71's Avatar
Default fuel pump wiring.
I recently did a walbroo 255 pump upgrade and now the car wont start. i have the black wire on the factory connector going to the black wire on the fuel pump wiring and the grey wire on the factory connector going to the red wire on the fuel pump connector. is this right? if so what else could be the problem?
Old Feb 23, 2012 | 02:45 PM
gMAG's Avatar
Is yours an external pump?
Either way, you need battery & ground.
Does that connector you've plugged into have this?
For my (external) Walbro, I wired a separate line for battery, & wired the ground lead of the Walbro to the car frame.
Old Feb 23, 2012 | 03:02 PM
98chevyz71's Avatar
it is the in-tank pump... i assume the wires coming off the pump are the positive and ground wires... they are the only 2 wires to the pump. and those the the wires i connected to the factory connector
Old Feb 23, 2012 | 06:27 PM
98chevyz71's Avatar
anyone?
Old Feb 23, 2012 | 07:57 PM
gMAG's Avatar
Can you hear the pump priming after you turn the key?
Old Feb 23, 2012 | 09:42 PM
98chevyz71's Avatar
i had music on, and wasnt really paying attention. i guess i shoulda tried listening before i pulled the pump back out/
