Square bore EFI intake set up
Old Feb 23, 2012 | 11:24 PM
the dan's Avatar
Default Square bore EFI intake set up
Hey guys recently purchased a Edelbrock square bore intake with injector ports to use on my Ls2 an i am wondering what throttle body/ MAF sensor combo to go with
I have a typical cable type LS1 throttle body and i can machine an adapter plate, or is there some sort of square bore/ mas air flow sensor set up
I searched and found an old post on PMAS Air Flow having a 4 barrel throttle body and MAF set up but i can no longer find it
any ideas?
thanks
dan
Old Feb 24, 2012 | 10:55 AM
Ollie8974's Avatar
I am using an Accufab throttle body.
includes the throttle position sensor and the air valve.
both use standard GM parts.
Attached Thumbnails Square bore EFI intake set up-040-efi-intake-manifold.jpg   Square bore EFI intake set up-044.jpg
Old Feb 24, 2012 | 03:49 PM
Old Geezer's Avatar
Thumbs up Yep!
What he said^^^^^^^^^^^^
Old Feb 24, 2012 | 07:36 PM
LS1NOVA's Avatar
Use your adapter plate idea, forget the maf, and tune in speed density.
Old Feb 25, 2012 | 09:41 AM
the dan's Avatar
sounds good, i have a good friend that tunes on a dyno so ill make him owe me a favor
only thing i wasnt sure of is im going to almost daily drive it between 50* and 90* weather, so is that going to effect it that much?
