Injector size
Old Feb 27, 2012 | 07:23 PM
Fast6.3's Avatar
Cool Injector size
Im building a stroked 6.3 5.3 iron block forged probe crank rods and dish pistons 9.5 cp dart ls pro1 heads 205 intake runner 62cc 224/228 @50 .581 .588 tsp cam comp 7.400 rods and lifters stock rockers trunnion upgrade typhoon 96 intake and fuel rails ls3 tb volant cai pacesetter 1 3/4 headers ypipe no cats everything else stock from a 2010 silverado. im wondering if the stock injectors are big enough also putting in a yank 2800 stall converter
Old Feb 28, 2012 | 08:51 AM
ZL1Killa's Avatar
i would say no.
grab some 36lb or higher injectors. Why the forged parts ? where is your forced induction? are you spraying?
Old Feb 28, 2012 | 05:19 PM
Fast6.3's Avatar
Planning on a 100 or 150 shot than maybe a procharger see what the funds allow I spoke to John at tsp he told me some trucks come with ls2 injectors and those would be fine if they are the 24 26. Lb/hr injectors than I will need larger researching part numbers to verify. you think the 36 will suffice with a 150 shot? Thnks
Old Feb 28, 2012 | 06:20 PM
jrane's Avatar
Are you gonna be running a Wet or Dry Shot?
Old Feb 28, 2012 | 10:06 PM
Fast6.3's Avatar
Im thinking of a wet 100 shot
Old Feb 29, 2012 | 08:29 AM
ZL1Killa's Avatar
36lb would work with a wet shot. go ahead and get 42# and be done
Old Feb 29, 2012 | 11:42 PM
Fast6.3's Avatar
Talked to sd parts and verified oem injectors found out they are 34 so will keep thanks for your help
