Fuel pump help!!!!!!!
you took your intake tube off, sprayed a rag with carb cleaner and put it across the MAF, then with the rag there, you cranked the car.
you cut an access panel? where to the fuel tank at the rear of the car? if thats so, then you should read 12 volts with all relays & etc ON.
you need not do the Carb cleaner and rag ordeal. There are also a lot of electrical connectors on the belly of the car, just above the rearend on the drivers side, check all of those. One set of those will be a 12V power to the pump ( or separate if you have a hotwire kit installed)
