Would this be enough for a 402 solid roller on E85?
Old Mar 11, 2012 | 09:31 PM
The Guy in MY 99TA's Avatar
Default Would this be enough for a 402 solid roller on E85?
I've got a iron 402 w/ Meaux stage III ls6s an FMS solid roller 259/267 topped with a ported Fast 90/90 setup. The compression is around 12.4:1ish. Its a nitrous setup but I'm hoping she'll break the 500rwhp mark w/ a th-400.
I've got mototron60lbers (I think thats the brand-- got em from speed inc) and a racetronix 255 intank. Running stock lines w/ speed inc rails w/ -6an lines running to the stock line.
Would this be enough fuel system to run this car on motor with E85?
I'm gunna crank the car w/ 100octane unleaded from VP. I'm gunna end up putting one of the aeromotive fuel cells in w/ the eliminator pump built in w/ -8 or -10 line once I get the T-top well cut out etc.
Old Mar 12, 2012 | 01:31 AM
Big Al's Avatar
I have an OT car that's 393 inches and has 73 pound injectors. It will run on E85, and starts easy with it. I can't help with how much fuel you're going to get in the engine with your setup. One way to see if you have enough injector/fuel supply is to put a EGT gauge in and keep an eye on it while you find out.
Al 95 Z28
