Need help finding (Race Tronics)
Old Mar 24, 2004 | 02:16 AM
lower et then u's Avatar
Default Need help finding (Race Tronics)
I was looking in to geting the dule in the tank pumps from Race Tronics but i can't find there web page or phone # if anyone know where i can get this set up it would be a big help.
Old Mar 24, 2004 | 05:32 AM
Black LS1 T/A's Avatar
Moderator
http://www.racetronix.com/
Old Mar 24, 2004 | 03:21 PM
SStroked 410's Avatar
good luck
I have tried over and over to find out how I can buy a DP set up for a 2001 Camaro but no luck, I guess people in Canada dont use Phones?
k/j
Old Mar 24, 2004 | 11:18 PM
Mike K.'s Avatar
I was able to get through to them via email. I think they just dont have the time to build the dp system for us. I guess there is just not enough interest for it to be profitible to them. Like I said though try an email they usually reply withen a couple days.
Old Mar 25, 2004 | 01:30 PM
I emailed them about 3-4 times in the past month or 2 and nothing?
Maybe they dont make enough money like you said, but there customer service needs some help
Old Mar 25, 2004 | 02:40 PM
Nasty N8's Avatar
I am looking into making a duel intank setup. If I could get a few people interested I could put it together for you guys. I can do it on a one order basis if you need one badly enough.
Nate
Old Mar 25, 2004 | 10:07 PM
Nate
I might be interested in one but about how much? I want to keep the stock fuel lines and I already have 1 walbro 340 intank?
Old Mar 25, 2004 | 11:15 PM
Mike K.'s Avatar
hey Nate what about making us a pre built front mount regulator system, say one that comes with all the fitting attached with a regulator so all we have to do is put on the new fuel rails with reg attached hook it into our stock fuel line and then run the line back to the tank? Maybe even some instructions on how to properly get the line back to the tank. I would definatly be interested in something like this.
Old Mar 26, 2004 | 08:08 PM
Nasty N8's Avatar
I do have a complete setup I can sell you it is not all assembled but I do get all of the parts together for you. As far as instructions what are you looking for? The line is pretty self explaining.
Stroked it is basicly worthless to add another pump and stay with the stock fuel line. The one Walbro will out flow the stock line and rails as it is. 2 you are going to need -8 line. And as I have said before I know what you are going for I would not try and skimp on the fuel system I would do it right and do a complete external pump and good line. You do not want to chance it with that setup.
Nate
Old Mar 26, 2004 | 08:34 PM
Mike K.'s Avatar
I am just not sure of how to run a return line back to the tank. More specifically do I have to do any altering of the tank? if not or if so what kind of fittings will I need and which adapter on the fuel pump harness would I need to use to plug in the return line?
Old Mar 29, 2004 | 09:46 AM
Moderator
MY understanding is just take a return fuel line frim the rail/s (different ways to do this) back to the line that goes into the fuel sender, remove the stock in-tank regulator, and place a hose to allow the fuel to expel where it did before.
This is a pic of the '98 fuel sender from that side the regulator is on:
I tried to zoom it in here:
The inlet from the top of the sender goes to the regulator and exits thru the dirty-brown accordion tube, which runs down to the bottom of the assembly.
This is a pic of when I did my dual-Walbro 340 mod.
Hope this helps!
Old Mar 30, 2004 | 05:51 PM
race tronics sucks tierd of e-mailing them going to do it my self this weekend i'll let u know how it go's
Old Mar 31, 2004 | 11:06 AM
Nasty N8's Avatar
There are some very good pictures on here to show you how to install them. I could setup the pumps in the stock canister with a bulkhead fitting out the top for the new feed line. Then you use the stock feed line as your new return line. Let me know I have the stock sender housings here.
Nate
Old Mar 31, 2004 | 01:35 PM
they sure do!
