Racetronix fuel pump question??
Old Apr 4, 2012 | 11:30 PM
suvettetexas's Avatar
Default Racetronix fuel pump question??
I just installed a new performance Racetronix fuel pump FPA001 and a new pump assembly/module from Racetronix into my 2002 firehawk, i now have to crank the car longer to get it to start than before, sometimes takes a little while, is this Normal ???? thanks
Old Apr 5, 2012 | 12:57 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Did you register for help in our support forum?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Apr 5, 2012 | 10:54 PM
No, didnt know there was one, but ill look, thanks
Old Apr 11, 2012 | 02:59 PM
NHRATA01's Avatar
If you can get a fuel pressure gauge on there and watch what it does as you crank, that will help diagnose.
For whatever reason, for about the first month I was running the racetronix setup, the fuel pressure would quickly bleed off after the pump cycled (in fact I think I posted a thread about this years ago, and the consensus was the racetronix check valve didn't work that well). If the car sat overnight, I would have to turn the key once to prime it, cycle it off, and then turn the key again to fire it right up, otherwise it would take a hair longer to crank. But even not doing that the crank time wasn't excessive, just longer then was typical with the factory pump. Surprisingly enough, the problem mysteriously went away after a month or so. 5 years later, the racetronix is still working flawlessly.
Old Apr 16, 2012 | 06:34 PM
aerojt's Avatar
Where is this support forum? I am in the middle of my install and I have only a one wire ground off the fuel pump, is this new? The instructions say two black wires going to the ground, but mine only has one on the racetronix unit. Thanks
Old Apr 16, 2012 | 06:38 PM
Racetronix's Avatar
LS1TECH Sponsor
Did you purchase this kit directly from us?
__________________
>WEB SITE<
Old Apr 16, 2012 | 06:39 PM
Racetronix's Avatar
LS1TECH Sponsor
Junk got into your fuel system which hung up the check-valve, bypass valve or regulator. It was purged and caught in your filter.
__________________
>WEB SITE<
Old Apr 19, 2012 | 07:29 PM
aerojt's Avatar
I got it from the ws6store, not sure if that helps me or not. Thanks!
Old Apr 19, 2012 | 07:35 PM
JUSTINSWS6's Avatar
I got mine from ws6 store about a month ago works fine.
Old Apr 20, 2012 | 11:33 AM
needtransam's Avatar
How do you check these items to make sure their is no junk and evade any possibility
Old Apr 20, 2012 | 11:39 AM
Racetronix's Avatar
LS1TECH Sponsor
Clean the tank.
Replace filter.
Do not allow any dirt to get into pump pickup.
__________________
>WEB SITE<
Old Apr 20, 2012 | 01:41 PM
Nasty N8's Avatar
Reason #1 to drop the tank to clean it when replacing.
Old Apr 20, 2012 | 04:06 PM
I can't drop my tank what options do i have of cleaning the tank??
Also how can I check for proper clean lines and to make sure the pick up tube works as well as the lines are getting proper fuel?? can you prime the pump manually?
